Ending tabulators cause error
cmatusch
Post by cmatusch »
if the content of a TRichViewEdit ends with a tabulator, I get the error
"Can't get or set this kind of information for this item" when I exit the TRichViewEdit.
The error comes from the
procedure TCustomRVData.GetTextInfo(ItemNo: Integer; var AText: String; var ATag: Integer); where I check, if the TRichViewEdit is empty or not.
procedure TForm1.TextRTFExit(Sender: TObject);
  szHilfRTFText1: String;
  nHilfTag:       Integer;
  KeyPreview := true;
  Text1RTF.GetCurrentTextInfo(szHilfRTFText1, nHilfTag);
  if (szHilfRTFText1 = '') then
    Label1.Caption := 'The RTF is empty.'
    Label1.Caption := 'The RTF isn''t empty.'
Thanks in advance for any help
Regards
Christian Matusch
GetCurrent*** methods return information about the item at the position of caret. GetCurrentTextInfo returns information for text item. If the caret is not in the text item (and tabulator is NOT a text item in TRichView), it raises the exception.
So this is by design.
What do you want to implement? Checking if TextRVF empty?
If yes, use this code:
  if (Text1RTF.ItemCount=0) or
    ((Text1RTF.ItemCount=1) and ((Text1RTF.GetItemText(0)='') ) then
cmatusch
Post by cmatusch »
That's the solution
