Scroll in View
BernhardRoos
Scroll in View
Post by BernhardRoos »
if I have controls in TRichview, is it possible that TRichView automatically scrolls that a control is in view if I navigate through the controls for example with tab
At the moment the controls get the focus but I can't see it if the control is outside of the visible part of the Richview.
Best wishes
Bernhard
LadyOfWood
Post by LadyOfWood »
I think you need to manually determinate that focus come to control and scroll TRichView to this control.
BernhardRoos
Is there an example how I can do this?
And is it possible to determine if it is necessary to scroll. I only want to scroll if the control is not in view.
Best wishes
Bernhard
BernhardRoos
Is it possible to get the coordinates of the top line, which is in TRichView current visible?
Best wishes
Bernhard
Visible area:
Top: rv.VScrollPos*rv.VSmallStep
Bottom: Top+rv.ClientHeight
As for the control. To get vertical coordinate, it's better to use Control.Tag instead of Control.Top.
TRichView stores controls' Y coordinates in their Tag properties (Control.Tag). It's because too large control coordinates (> 30000 pixels) are not processed correctly by Windows. Control.Tag always contains the correct coordinate, Control.Top is limited to 0..30000 range.
