With the clicks cell the content a spreadsheet in Edit shows
Jmich
Post by Jmich »
With the clicks one single table cell the cell-content with Edit shows. Who can help?
Thank you
JM
Sorry, I do not understand your question.
Jmich
Post by Jmich »
if I click on a cell in a table of Richviewedit, this content of the cell in a Tedit field should be shown.
For example: if select rich_table.Cells[r,c] = true then
edit1.Text := rich_table.cells[r,c];
How can of working?
Many greetingses
Jmich
Use OnRVMouseDown event.
procedure TForm3.RichViewEdit1RVMouseUp(Sender: TCustomRichView;
  Button: TMouseButton; Shift: TShiftState; ItemNo, X, Y: Integer);
  if (Button<>mbLeft) or (Shift<>[]) then
  if RichViewEdit1.InplaceEditor<>nil then
    Edit1.Text := GetAllText(RichViewEdit1.TopLevelEditor)
    Edit1.Text := ''; // not a cell
GetAllText is declared in RVGetText unit.
Note: it may return multiline text.
