Zala
Posts: 12 Joined: Mon Jun 09, 2008 8:02 pm
Post
by Zala » Thu Jul 10, 2008 6:06 pm
I'm in a TDBRichViewEdit and I'm editing the component with a custom editor that use the RichViewAction.
My problem is that when I post my content in my database, some of my style are missing. Like the underline, the bold, etc...
So I need to know witch options I need to set to have all my style saved and loaded properly.
Regards,
Zalathorn
Zala
Post
by Zala » Thu Jul 10, 2008 6:16 pm
In fact, I can save the style like bold and underline, it's more the bakgroung, the bidiMode, the strike, etc...
Thank you,
Zala
Posts: 17847 Joined: Sat Aug 27, 2005 10:28 am
Post
by Sergey Tkachenko » Sat Jul 12, 2008 6:17 pm
Right click the editor in Delphi, choose Settings in the popup menu, set "Allow adding styles dynamically" mode. Do it both for editors that save data and for editors that display data.
Zala
Post
by Zala » Mon Jul 14, 2008 2:56 pm
I didn't found the Setting button in the "Popup Menu".
Am I suppose to right on the TRichViewEdit in Design Mode and then choose Settings?
Post
by Sergey Tkachenko » Tue Jul 15, 2008 8:07 pm
Yes, right click the TDBRichviewEdit at design time, a context menu will appear, and its first item is "Settings"
Zala
Post
by Zala » Wed Jul 16, 2008 6:51 pm
I found it...right where you said it was the first time. I suppose I just didn't look really well.
But now, I use a lot of heritage. So is there a way to set this option programatically?
Zala
Post
by Zala » Wed Jul 16, 2008 6:54 pm
I found that the function just set Options in design time, so I just need to set them programatically.
Thank you.
