When i save, edit and save again an HTML with a table trichview changes on second save the table border from 1 to 4 (without making some changes to it).
I use rvsoNoDefCSSStyle option forced.
How can avoid this?
thnks for all and best regards,
Javier Orellana
Problem saving HTMLex with table
I suppose you use Pbear's html importer. Unfortunately pbear's component has a bug in loading table border, in some cases it makes it 4 pixels. I'll try to find this bug. meanwhile the latest version of trichview has define / see rv_defs.inc / to generate html compatible with this parser / by adding some unnecessary tags
