How to focus on the speciefied inserted item
wray
Post by wray »
Please give me ahint how to focus programatically on the specified item added.
For example i add a Text Edit like this:
TspSkinEdit * edit = new TspSkinEdit(this);
RichView1->AddControlEx("",edit,-1,rvvaBaseline);
RichView1->Format();
int ItemNo = RichView1->ItemCount-1;
I got the item number, how can i focus in the added Text Edit ?
Thank you
P.S. I tried RichView1->RVData->FocusedItemNo = ItemNo; but does not focus...
wray
Post by wray »
Done.
If you need it in the same function:
ActiveControl = edit;
if not, just retrieve the pointer and asign it to ActiveControl.
Sorry to bother you... :)
The simplest way is to call edit->SetFocus() after this code.
(If you know item index, check if this item really contains a control (RichView1->GetItemStyle(ItemNo)==rvsComponent, then get this control (RichView->GetControlInfo), and call SetFocus for the retrieved control. But if you already has it assigned to the "edit" variable, it is not necessary)
