How to iterate all words in TRichView ?
nostradumbass
Post by nostradumbass »
Hi.
I am using TRichView component. I want to iterate all the words in the content, but am not able to do this, as GetItemText returns the paragraph. I need each individual word, because I am doing a find/replace operation.
Please help me how to do it. Thanks!
Regards,
NotraDamus
Here is my code:
 richviewedit1 : TRichView;
 richviewstyle1 : TRVStyle;
 c,d :integer;
 s:string;
 richviewedit1 := TRichView.Create(nil);
 richviewstyle1 := TRVStyle.Create(nil);
 richviewedit1.Parent:=application.MainForm;
 richviewedit1.Style:=richviewstyle1;
 emlmsg.MsgBody.Position:=0;
 richviewedit1.LoadRTFFromStream( emlmsg.MsgBody );
 richviewedit1.Format;
 for c := 0 to richviewedit1.itemCount - 1 do
   if richviewedit1.GetItemStyle(c) >= 0 then
     for d := 0 to replaceables.FindList.Count - 1 do
       if  trim(richviewedit1.GetItemText(c)) = trim(replaceables.FindList[d]) then
         richviewedit1.SetItemText(c, replaceables.replaceList[d]);
 richviewedit1.SaveRTFToStream( emlmsg.MsgBody, false );
 richviewedit1.Parent:=nil;
 richviewedit1.Free;
This is the fastest way to replace text in TRichView.
But if document contains tables, your code does not replace text in table cells. To process tables, create your procedure basing on AllUpperCase example.
And remove all these calls of Format, call Format only one time, before SaveRTFToStream.
There is a word enumerator class, used by spell checkers, but it will be much slower, because it was designed to replace words as an editing operation (undoable).
Afer you get the item text (it's better to use GetItemTextA/SetItemTextA instead of GetItemText/SetItemText), you can separate it into words yourself.
