LoadRTF containing a table into idented paragraph
YannickM
Post by YannickM »
I'm currently having some trouble when loading an RTF containing a table into a document that has indentation.
Code snippit:
RichViewEdit1->RTFReadProperties->ParaStyleMode = rvrsUseSpecified;
RichViewEdit1->RTFReadProperties->ParaStyleNo = iParagraphStyle;
Stream->Position = 0;
RichViewEdit1->LoadRTFFromStream(Stream);
RichViewEdit1->RTFReadProperties->ParaStyleMode = rvrsAddIfNeeded;
The problem occurs when a user has an indented paragraph, and attempts to insert an RTF containing a table.
The table's values get wrapped.
Is there a way to correctly add the table (indented) without changing its appearance?
Thanks.
What do you mean by "The table's values get wrapped"?
YannickM
Post by YannickM »
For instance, if the table would contain a value:
$123,456,789.00
this value would be wordwrapped to something like:
$123,
456,
789.
00
The table's cells become much higher, and narrower. It seems as the table is squeezed together.
Edit:
It seems as if each table cell gets the left Indentation I used for the paragraph. So for example, the table is indented 2cm, and each cell is also indented 2cm, which makes it wrap the text in the cells.
Of course, with these settings, if the iParagraphStyle-th paragraph style has indents, they will be used for every paragraph in the imported document, including tables and paragraph inside all cells.
