I try to replace text part of RichViewEdit1 by another text part of RichViewEdit2.
I use SetItemTextA but I loose #10 and #13 caracters.
Thank you for help
Regards
Replace text part of RichViewEdit1 by text part of RichViewE
Sorry, what do you mean by replacing text part?
If you want to copy document as a plain text (without all text and paragraph attributes, images, tables, etc.) use this code:
var Stream: TStringStream;
Stream := TStringStream.Create('');
RichViewEdit1.SaveTextToStream('', Stream, 80, False, False);
RichViewEdit2.Clear;
RichViewEdit2.AddTextNLA(Stream.DataString, 0, 0, 0);
RichViewEdit2.Format;
Stream.Free;
