RTF & Invisible table
Benoit B.
Post by Benoit B. »
When I import a RTF file with table, the table is invisible and i see only text.
How to do for see the boxes of the table ?
Benoit B.
Post by Benoit B. »
PS : AutoHide TableGridLines value is false
Benoit B.
Post by Benoit B. »
I've more information about my problem.
When i do tables with an other software, I can see grid lines in my TRichView.
But if I do tables with RichView componants, I don't see the Grid lines with TRichView, but I can with Microsoft Word.
Do you know what is the problem please ?
Benoit B.
Post by Benoit B. »
In fact, the lignes appears only if I open my RTF with Word and I do "save as", in RTF format.
Help please ?
Benoit B.
Post by Benoit B. »
I think the RTF file make by my software is understood by Word but not by RichView.
Can I do something ?
I tried to reproduce this problem in this simple project:
http://www.trichview.com/support/files/tablegrid2.zip
The form has a button. When you click on it, the document is saved to RTF file and reloaded. Table grid is not disappeared.
Benoit B.
Post by Benoit B. »
In fact, I've RTF files that work with word but not with richview ( I think the syntax is a little different )
I try to find a other way to do.
Thanks.
Please send me this RTF file by e-mail, I'll try to see what's wrong with it.
Benoit B.
Post by Benoit B. »
I've changed my RTF Format and now it works.
In fact, my old format was working only with Word2003 and did not work with all the others.
In fact, I've included my own translator in my programme for this curious format.
Thanks for your super component ;)
Vacquer
Benoit B
Post by Vacquer »
Many thanks to contact me
to [email protected]
Benoit V
Benoit B.
Post by Benoit B. »
Hi Vacquer,
Was the preceding message for me?
Sorry of this small time for the answer.
PS: I am French too :)
