The action test doesn't scrooll to finding word(s) ?
zekeriye
Post by zekeriye »
At the action test, when we used find some text at the loaded document the find dialog does not scroll to finding documents. Find but we didn't see the finding documents. (At richaction test the fidn dialog scroll to the finded words)
How we can solve this?
proxy3d
ScaleRichView Developer
Post by proxy3d »
See Example: Basic Demos\Search and Replace
zekeriye
Post by zekeriye »
Basic Demos\Search and replace demo is find and scroll to finded words. But Rich action test does not ?
We need scroll functionality at the rich action test, same as Search and resplace demo. Because we have got modified rich action and it used an editor.
We will try to fix this problem in the next update of ScaleRichView.
zekeriye
thanks
Post by zekeriye »
we update scalerv to 1.4.1 ;
this problem solved
thanks
