Hi;
At some of documents; after loading the documents scalerichview only display background. After the moving scrollbar the documents display normal. Most of our documents are RTF.
Have you any idea to solve the problem ?
ps:We used zoom factor %100 and Paper size A4 always in the program.
View problem some documents
I was recevied update by email and applied. But this bug has not fixed.
If not scroll to end of first document no problem has got. After scrolled first document and loading second document this problem occuring.
Document format is not important. Both RVF and RTF format same problem occur.
Richview haven't got this problem. After loading second document richview scrolled correctly the end of document.
Hi;
After I updated the scalerv and restart my computer (today) and recompile myprogram. Thats all. The bug is fixed.
thanks to all.
thanks to all.
