List out of bounds Exception in TRVEditRVData.GetCurItemNo
Michael Pro
Post by Michael Pro »
Sergey, I've got one nasty bug - sometimes while drag'n'drop selected text I've got this exception.
I'm calling actions update on OnCaretMove event - and inside it I'm calling this function.
I'm making drag'n'drop in tables - and sometimes this bug happens.
Any ideas about that?
Michael.
Michael Pro
Well, I think, that document in this case simply unformated - but why this happens, I couldn't say.
I made some modifications - don't know, am I right...
function TRVEditRVData.GetCurItemNo: Integer;
  function IndexOf(obj: TObject): Integer;
    if not Assigned(DrawItems) then
      Result := -1;
      Exit;
    if CaretDrawItemNo > DrawItems.Count - 1 then
      Result := -1;
      Exit;
    if DrawItems[CaretDrawItemNo].ItemNo > Items.Count - 1 then
      Result := -1;
      Exit;
    if (CaretDrawItemNo>=0) and (Items.Objects[DrawItems[CaretDrawItemNo].ItemNo]=obj) then
      Result := DrawItems[CaretDrawItemNo].ItemNo
      Result := Items.IndexOfObject(obj);
  PrepareForEdit;
  if FPartialSelectedItem<>nil then
    Result := IndexOf(FPartialSelectedItem)
  else if GetChosenItem<>nil then
    Result := IndexOf(GetChosenItem)
  else if CaretDrawItemNo=-1 then
    Result := -1
    if CaretDrawItemNo <= DrawItems.Count - 1 then
      Result := -1;
OnCaretMove may be called when the document is not formatted yet.
Selection-related methods must not be used in this event, but methods related to the caret position must be available.
Do you use RichView 10.0? It looks like all checks for the range of CaretDrawItemNo are already implemented.
Michael Pro
Sergey Tkachenko wrote:Do you use RichView 10.0? It looks like all checks for the range of CaretDrawItemNo are already implemented.
Actually, no. We've bought 1.9 version on 3rd of March in 2006.
Maybe I could use OnAfterCaretMove event to make changes on my actions?
Michael Pro
Or maybe it's simplier to check rvstEditorUnformatted flag in editor state before actions updating?
Michael Pro
Not sure, but with this code my actions started worked fine
  if (rvstEditorUnformatted in RvData.State) or (rvstMakingSelection in RvData.State)
    or (rvstDeselecting in RvData.State) or (rvstStartingDragDrop in RvData.State) or
    (rvstForceStyleChangeEvent in RvData.State) or (rvstLineSelection in RvData.State)
    or (rvstClearing in RvData.State) then
    Exit;
Sergey, could this part solve my troubles for updating?
Best regards,
Michael.
Michael Pro
Won't help (((
Sometimes RVData is in rvstForceStyleChangeEvent state - and it won't help ((((
These flags are for internal use and do not necessary mean that you expect.
You can upgrade to version 10.0, it's free.
Michael Pro
I've found the reason - sometimes Self-editor stay unformatted, while in TopLevelEditor everything is ok.
I think, that I gonna rewrite code in few days - if the trouble stay, I'll write about it.
