Hi
I nead your help!
How can I append several text-styles at the same line into table.cells (by code)? Is it possible?
with table.cells(r,c)
do begin
AddNL(), AddTextNL() (Creates new lines for each TextStyle)
Add(), AddText() (aren't usefull)
Several TextStyles in same line into Table.Cells
You can use AddNL() with ParaNo parameter = -1. This means adding in the same paragraph as the previous line. Such calls of AddNL() (with ParaNo=-1) are the same as calls of Add().
AddTextNL() can be used too (with FirstParaNo parameter = -1).
AddText() is a deprecated method.
PS: Each cell initially has one empty text item. Before adding new text, you can delete it by calling Cell.Clear().
Last edited by Sergey Tkachenko on Wed Apr 09, 2008 5:51 am, edited 1 time in total.
