Export Header/Footer to RTF
Cosimo
Post by Cosimo »
Hi all,
I have 2 RichView on my form: RichView1 is the body of my document, RichView2 is its header/footer.
I can print header using RVPrint1.SetHeader(RichView2.RVData).
Now I need to export my header + document to a RTF file.
How can I do it? The RichView1.SaveRTF() method save only the body, but not the header.
Thanks in advance,
Cosimo.
Yernar Shambayev
Post by Yernar Shambayev »
use OnSaveRTFExtra event
Unfortunately, it's not so trivial.
OnSaveRTFExtra can be used to save plain text headers, or headers with some simple formatting.
Saving arbitrary TRichView document as RTF header is not possible in the current version.
Cosimo
Post by Cosimo »
Sergey Tkachenko wrote:Unfortunately, it's not so trivial.
mmmh... ok. Is it planed for next version of TRichView? I'm very interested to buy the site licence... but I need that function :wink:
Thanks for support,
Cosimo.
Well, really? :)
It's not so hard to make a "quick and dirty" solution for this problem.
So, if you are satisfied with other TRichView feature, consider this function done
Cosimo
Post by Cosimo »
Sergey Tkachenko wrote:Well, really? :)
Hi Sergey, what's new on this topic?
I really need that function... :wink:
Thank you for ordering Site License :)
Please remind me when I upload the next update (supporting page breaks in table cells), I'll immediately start working on this problem.
Cosimo
Post by Cosimo »
Sergey Tkachenko wrote:Thank you for ordering Site License :)
Ok! :wink:
Thanks,
Cosimo.
radekg
Post by radekg »
Is there any update on this issue?
Thanks,
Radek.
Sorry, it still not complete, implementing page breaks in tables took too long time. It will be implemented next.
Ladig
Post by Ladig »
Sergey Tkachenko hat Folgendes geschrieben:
Thank you for ordering Site License Smile
Can I save now Header und Footer in rtf, if yes how?
Thanks,
Andre
Please wait, it will be only after releasing the next major update
Ladig
Post by Ladig »
How long I must still wait. I´s important for my project. :?
Thanks,
Andre
I'll implement it as soon as it will be possible after releasing the next update. This update is almost ready, we just need to finishing web site update translation to several languages.
This update must be stable, so I do not plan to make serious changes in code before releasing it, sorry.
Ladig
Post by Ladig »
Can I save header/footer in rtf now with the new version. :?:
