Hi, I just need to know if my doc. has hyperlinks in it (I don't really care to know the number of them). This should be done just before the call to SaveHTMLToStreamEx. Any hint appreciated
Thanks in advance, Dan
RVE Doc. contains links ?
The simplest way is using RichView.RVData.EnumItems:
See also http://www.trichview.com/forums/viewtopic.php?t=397
procedure TForm1.EnumLinks(RVData: TCustomRVData; ItemNo: Integer;
var UserData1: Integer; const UserData2: String;
var ContinueEnum: Boolean);
ContinueEnum := not RVData.GetItem(ItemNo).GetBoolValueEx(rvbpJump, RVData.GetRVStyle);
if not ContinueEnum then
UserData1 := 1;
function TForm1.HasLinks(rv: TCustomRichView): Boolean;
var r: Integer;
r := 0;
rv.RVData.EnumItems(EnumLinks, r, '');
Result := r<>0;
