1) In RVEdit, I select an image inserted with rvActionInsertImage, I right-click it then choose 'Object Properties' and I change the image.
2) then I export with
RichViewEdit1.SaveHTMLToStreamEx(streamRVEHtml,'','','','','','',
[rvsoMiddleOnly, rvsoUseItemImageFileNames, rvsoImageSizes,
rvsoNoHypertextImageBorders, rvsoMarkersAsText, rvsoNoDefCSSStyle,
rvsoInlineCSS]);
3) The generated HTML retains and shows the old image but with the new image dimensions and other properties. Strange...
What am I doing wrong?
Thanks, Dan
rvActions-Object Properties problem with images
In the previous versions of RichViewActions, TrvActionItemProperies did not change rvespImageFileName property of picture-items when the user chose another picture.
You include rvsoUseItemImageFileNames in the Options of SaveHTMLEx. Because of this options, picture-items with non-empty value of rvespImageFileName property are not saved to files, but value of this property is written in HTML instead.
You need to install the latest version of RichViewActions (v1.59) and set rvActionItemProperties1.StoreImageFileName = True.
