CSS - BODY definiton not wanted
vega
Post by vega »
I inject CSS generated by RVE into a larger document and I don't want BODY etc. to be redefined by RVE.
I modified the source and got rid of the "body, table /* Normal text */ {...}" definition. Now, the problem is that there is no default defined for rvts0 and rvps0. The browser's default font and color are used when these 2 styles are invoked in HTML.
The same problem occurs with the "p,ul,ol /* Paragraph Style */ {...}" definition.
I really need help on that one before screwing everything up... Maybe I missed something.
Thanks in advance for any pointer, Dan.
PS: I make the suggestion to have a "Export to HTML" section in the forum. It would make things much easier for people who use this very powerful part of RV.
There is an option what does exactly what you want: rvsoNoDefCSSStyle. Include it in the Options parameter of SaveHTMLEx.
Note: this option greatly increases CSS size, because without defining default properties, it is required to specify all properties of all styles explicitly.
I do not think that addition of new forum is necessary. People already have problems to find the proper forum to post.
