Pdf generating problem
PiotrB
Post by PiotrB »
I use llPDFLib to generated pdf from TRichView. When I try open this document, Accrobat reports "The embedded font 'Arial' cannot be extracted". Sometime, the error occurs for 'Arial Bold'. Have you any idea of the reason of this problem and the way to fixed it?
I will be wery grateful for your help.
I am afraid I cannot help. TRichView only draws page onto Canvas provided by LLPDFLib. All low level work is done by LLPDFLib.
You should address this question to them. Or try to find options for font embedding.
toolwiz
Post by toolwiz »
I've never tried embedding the fonts, and have not run into any problems.
-David
nostradumbass
Help
Post by nostradumbass »
Using the free PowerPDF components:
www.est.hi-ho.ne.jp/takeshi_kanno/powerpdf
Can you give an example on how to render the RVHelper onto the PDF canvas? I saw the examples (simple and advanced) posted in Demos, but this component is different.
Thanks,
ND
