for this code:
RichView1->AddNL(TimeToStr(Now()) + " ", 2, 0);
RichView1->AddBulletEx("", 2, ImageList1, -1);
RichView1->Add(" Test line: ", 2);
RichView1->Format();
How do i get the bullet to be vertically centered like the text is ? Basicaly to be on the same level with the text becuase now is a couple pixels upper... If you select both the text and the bullet you will understand what i am saying.
Thank you
Vlad
Bullets centering
VAlign property is available for bullets, so it's possible to change it from baseline to middle, abs-middle, abs-top or abs-bottom.
But this property was added to bullets later than adding AddBulletEx method, so you need to set it manually:
((TRVBulletItemInfo*)(RichView1->GetItem(RichView1->ItemCount-1)))->VAlign = rvvaAbsMiddle;
