I have all tried but found not the solution. If I insert a table in the editor, there are frames (black lines around the cells and lines around the table). The frames in the cells I was able to delete, but how can I delete the frame around the table?
I did the following in the table :
1. Inserting a table
2. Mark the whole table
3. Go in properties and deactivate the lines
The result : The lines around the cells are gone, but not the lines around the table.
What can I do to solve the problem?
Best wishes
Bernhard
Frame of the table
