How can i get the Column Size ?
mediasofts
Post by mediasofts »
It's possible to set the column size with "Table.ResizeCol"
But how can i get a column size ?
I use the property "Table.cells[0,i].Width", but it doesn't work well ...
More informations :
"I need to memorize the column width of a table
and set there column widths to another table (with the same count of column)"
:arrow: How I get the colWidths :
for j := 0 to TableSource.ColCount-1 do
  ColWidth[j] := TableSource.cells[0,j].Width; // Problem Here ! this is not the real width
:arrow: How I Set the ColWidth to another table :
for j := 0 to ColWidth.Count-1 do
   Table.ResizeCol(j,ColWidth[j]) ,true);
:) Thanks !
David
mediasofts
More informations
Hi ,
I Use a "non-percent" width (width > 0).
I find this on "RVTable.pas" L 7557:
procedure SetWidth(c,w,x: Integer; Decrement: Boolean);
  var r,a,b,a1,b1,oldw: Integer;
      Changed: Boolean;
      Cell: TRVTableCellData;
    oldw := w-CellHPadding*2;
    if Decrement then begin
      if c<ColCount-1 then
        x := Fmt.ColStarts[c+1] - (CellBorderWidth+(CellHSpacing+1) div 2)
        x := Fmt.FWidth-(BorderWidth+BorderHSpacing+CellBorderWidth{+1}) div 2;
      x  := x + (Fmt.ColStarts[c]-Fmt.ColStarts[c-1] - (CellHSpacing+1) div 2)-w-CellBorderWidth;
      w := x - Fmt.ColStarts[c];
    a := w;
    dec(w, CellHPadding*2);
    if c<ColCount-1 then begin
      dec(w,CellBorderWidth);
      dec(w, CellHSpacing div 2);
      end
      dec(w, (BorderWidth+BorderHSpacing+CellBorderWidth+1) div 2);
    //inc(x, w-a);
    if w<=0 then w := 1;
    Changed := False;
    for r := 0 to RowCount-1 do
      if (Cells[r,c]<>nil) and (Cells[r,c].ColSpan=1) then begin
        SetCellBestWidth(w,r,c);
        Changed := True;
      if (Cells[r,c]=nil) then begin
        Cell := Rows.GetMainCell(r,c,a,b);
        if (b=c) or Decrement then continue;
        if (c=ColCount-1) or
           (Cells[r,c+1]<>nil) or
           (Cell<>Rows.GetMainCell(r,c+1,a1,b1)) then begin
          if Changed then
            w := 0
          else begin
           // w := x-Cell.Left;
            w := Cell.Width - Fmt.ColWidths[c]+oldw;
            if w<=0 then
              w := 1;
          SetCellBestWidth(w,a,b)
I try to understand how it works :D
Thanks for help !
David
mediasofts
Investigation....
:idea: This might be correct :
if (C=0) or (C=ColCount-1) then
  ColWidth := CellWidth + (CellBorder*2) + BorderHSpacing + (CellHSpacing div 2)
  ColWidth := CellWidth + (CellBorder*2) + (CellHSpacing);
:lol: David
Normally, width of cells are calculated basing on BestWidth properties of table cells. Consider assigning BestWidths properties from one table to another. There may be a problem with merged cells, or if cells in the same column have different BestWidths, though.
Widths of columns are stored in Fmt.ColWidths, but you cannot access it because it is a private property. Cell.Width may help, but it does not include border width and spacing. Honestly, I do not remember this stuff exactly, but if your code look right, and if it works, it is correct :)
mediasofts
Final function ....
Works only if there are no Merged Cells.
And without percentCellWidth (width > 0).
function ComputeColWidth(Table: TRVTableItemInfo; NoCol: integer): integer;
  Delta : Integer;
  Delta :=  Table.CellPadding *2;
  if (NoCol=Table.ColCount-1) then
    // Last Column
    Delta := Delta + (Table.BorderWidth+Table.BorderHSpacing+Table.CellBorderWidth+1)div 2;
  end
    // Other Column
    Delta := Delta + Table.CellBorderWidth + Table.CellHSpacing div 2;
  result := Table.Cells[0,NoCol].BestWidth + Delta;
I've created a public property
property ColWidths_Mediasoft:TRVIntegerList read GetColWidths_Mediasoft;
function TRVTableItemInfo.GetColWidths_Mediasoft: TRVIntegerList;
  result := fmt.ColWidths;
But it doesn't work like i want ...
Thanks Sergey
David
Pieter Zijlstra
Post by Pieter Zijlstra »
The following is what I use to determine the colwidths of the current row (see RVRuler.pas in UpdateTableEditor for more).
          if RulerType = rtHorizontal then
            // Setup columns
            RVCellLast := nil;
            for C := 0 to RVTable.Rows[Row].Count - 1 do
              RVCell := RVTable.Cells[Row, C];
              if RVCell <> nil then
                TableEditor.Cells.Add.CellWidth := M * RVCell.Width;
                RVCellLast := RVCell;
              end
                RVCell := RVTable.Rows.GetMainCell(Row, C, MainRow, MainCol);
                if RVCellLast <> RVCell then
                end
                  TableEditor.Cells.Add.CellWidth := -1;
Note that this is the width of the cell without borders, spacing, etc.
The hint is to check GetMainCell when dealing with merged cell.
HTH
