Insert gif-image(animated) into TRichViewEdit from stream
tors
Post by tors »
How too Insert gif-image(animated) into TRichViewEdit from stream
(TMemoryStream)
It is necessary that gif-image was stored in the document
( Is direct in a rtf-file)
Need that gif-animation play in TRichViewEdit.
If gif image is stored in TMemoryStream, you can load it in the proper graphic class (see http://www.trichview.com/forums/viewtopic.php?t=89) and insert:
var gif: TGifImage;
gif := TGifImage.Create;
Stream.Position := 0;
gif.LoadFromStream(Stream);
RichViewEdit1.InsertPicture('', gif, rvvaBaseLine);
See the topic referenced above how to turn on animations.
But you cannot store gif images in RTF (Rich Text Format) files. This format supports bitmaps, metafiles, png, jpegs, but not gifs.
You can store gif images in RVF files.
tors
Post by tors »
I am set:
RichViewEdit.AnimationMode:=rvaniOnFormat;
but gif-animation dont play
Did you include the proper file in your project?
RVGifAnimate2007 for Delphi 2007, or
RVGifAnimate for Anders' TGifImage, or
RVJvGifAnimate for JVCL Gif Image?
tors
Post by tors »
I am download Anders Melander's TGifImage and
update.
Add unit RVGifAnimate into project
(uses)
GifImg4Paste:=GifImage.TGifImage.Create;
GifImg4Paste.LoadFromFile('c:\aa.gif');//load animated gif
GifImg4Paste.Animate:=true;
//GifImg4Paste.AnimationSpeed:=1000;
RichViewEdit.InsertPicture('',GifImg4Paste,rvvaBaseLine);
animation dont play
Please send me a simple project to reproduce
