Tables and Controls
BernhardRoos
Tables and Controls
Post by BernhardRoos »
If I set controls (TEdit,TCombobox, ...) in a Table, then I can't select it (even I've set the extra int property to rvepResizable.
Is there to do anything else?
Best wishes
Bernhard
You should be able to select and resize them. There is only one problem: when the control is in the cell, TRichView cannot draw resize handles outside this cell. It may be a problem if CellPadding is small.
BernhardRoos
Hm... I've made very big cell and inserted into this cell a TEdit. But I cannot select it (and so not resize it). The Inserting of the Control I've made in the same way as I've inserted outside a table cell. Outside table it works and inside table cell it works not.
Perhaps I'm missing something.
Here is my insert routine :
RichViewEdit1.InsertControl('', c, rvvaAbsMiddle);
RichViewEdit1.SetItemExtraIntProperty(RichViewEdit1.FindControlItemNo(c), rvepResizable, 1);
Best wishes
Bernhard
The correct code is:
if RichViewEdit1.InsertControl('', c, rvvaAbsMiddle) then
  RichViewEdit1.TopLevelEditor.SetItemExtraIntProperty(RichViewEdit1.TopLevelEditor.FindControlItemNo(c), rvepResizable, 1)
or
  RichViewEdit1.TopLevelEditor.SetItemExtraIntProperty(RichViewEdit1.TopLevelEditor.CurItemNo, rvepResizable, 1)
or
  RichViewEdit1.SetCurrentItemExtraIntProperty(rvepResizable, 1, False)
BernhardRoos
Now it works fine. Thanks again for the very good support.
Best wishes
Bernhard
