table, with zero linewidth
Stef
Post by Stef »
If I insert a table with zero linewidth, (calling RVE.format afterwards),
I don't see any (dotted) lines in my editor.
After closing and reopening the document,
the zero linewidths are beautiful displayed as dotted lines in RVE.
I probably set some property wrong, but cann't figure out which.
Any explanation / solution ?
cheers,
If you do not use RichViewActions, grid is controlled by the following variables
RichViewTableGridStyle: TPenStyle = psDot; // in editor
RichViewTableGridStyle2: TPenStyle = psClear; // in viewer and read-only editor
RichViewTableGridColor: TColor = clBtnFace;
These variables are not saved in files, so reloading must not affect them.
But read-only mode does.
Stef
Post by Stef »
thanks Sergey, but I don't get it.
I've a table in a RVE, and a radiogroup that sets the linewidth by it's itemindex, like the code below
  RVEx.BeginItemModify(ItemNo, Data);
  table.BorderWidth:=radiogroup.ItemIndex;
  // table.CellBorderWidth:=radiogroup.itemindex;
  RVEx.EndItemModify(ItemNo, Data);
  RVEx.Change;
Borderwidths of 1,2,3 are working correctly,
but whether I use borderwidth or cellbortherwidth,
with itemindex=0, the borders disappears completly.
The RVE is not in readonly mode.
cheers,
I created a very simple project trying to reproduce this problem:
http://www.trichview.com/support/files/tablegrid.zip
But it works as expected, table grid is shown.
Stef
Post by Stef »
thanks very much Sergey,
your example helped me very quickly to identify the problem,
after porting all my code to your example,
the problem arised,
then I saw I had made a stupid mistake,
I did add rvtoHideGridLines !!
Sorry for bothering you,
but I really have stared several evenings at this problem,
and couldn't find it.
cheers,
