RichViewEdit1.Paste doesn't work inside the table cell.
Marsianin
Post by Marsianin »
I'm using RichViewEdit1.Paste to control what I want to paste before doing it.
But RichViewEdit1.Paste doesn't works when I have cursor inside the table cell.
Sorry, I cannot reproduce this problem.
Marsianin
Post by Marsianin »
This code doesn't works when cursor inside the table:
if RichViewEdit1.Focused then RichViewEdit1.Paste
.Focused returns False if we're inside the table.
Then remove IF.
Marsianin
Post by Marsianin »
What you mean?
I need this if because my Paste menu can paste into a different controls.
I changed my code so it works now but this is a bug in TRichView.
It is not focused because its child control (cell inplace editor) is focused instead.
Use RichViewEdit1.FocusedEx
