Always unable to export to MS Word
Marsianin
Post by Marsianin »
When trying to export as MS Word file with RVActions I'm always getting error:
Error saving file.
Possible reasons:
- out of disk space;
- disk is write protected;
- etc...
Using Delphi 2007 SP3, Vista Ultimate x64, Office 2007 SP1, RichView 1.9.48 (but compiled exe can't export on other systems too)
Please send me compiled exe to richview at gmail dot com
(zipped with password protection, otherwise it will be rejected by gmail)
Marsianin
Post by Marsianin »
Just tried to export into .docx and .doc in your standard Actiontestd2007 - same thing, unable to export.
Pieter Zijlstra
Post by Pieter Zijlstra »
Sergey Tkachenko wrote:Please send me compiled exe to richview at gmail dot com
Just for information:
The last time I checked this, it didn't work. The filenames inside a password protected zipfile are still visible and gmail rejects .exe files. To send exe files change the extension to something else (.xex for instance) and then zip it using a password.
At least changing to jpg helps, not sure about changing to unknown extension.
Marsianin
Post by Marsianin »
What about export guys? It doesn't works. Even in RVActions demo.
But now I'm going to use TRVOfficeConverter directly. Will let you know results.
Marsianin
Post by Marsianin »
The same thing with RVOfficeConverter.
This always returns false:
RVOfficeConverter1.ExportRV(SaveDialog1.FileName,RichViewEdit1,1)
But export converters are available.
What's the value of RVOfficeConverter1.ErrorCode after calling RVOfficeConverter1.ExportRV?
Marsianin
Post by Marsianin »
RVOfficeConverter1.ErrorCode = -14
According to documentation, this error means "wrong file type for this converter". I do not know how it is possible for export converters.
Does this error occurs on computers without Office 2007? Sorry, I do not have this version of Office to test.
Marsianin
Post by Marsianin »
I tried to install Office 2003 instead of 2007 and it works with 2003, but RVOfficeConverter gives me only one converter:
Word 97-2002 6.0/95 - RTF
with .doc extension :shock:
Works fine but exports to RTF with DOC extension.
I think you should get the Office 2007 and test it yourself.
You can download it (trial) directly from Microsoft web site
Marsianin
Post by Marsianin »
Any suggestions?
Marsianin
Post by Marsianin »
Hello!
Still NO export under Office 2007!
Unfortunately, I can confirm the problem with new export converters, but I cannot provide a solution at this time. They just fail, I do not know why.
Pieter E.
Post by Pieter E. »
Could OLE Automation be a temporary solution?
