Unable to open file RVScroll.obj with Codegear BC++2007
Artaud
Post by Artaud »
I have add the component RVStyle to my form, I build it and I obtain this message
What I have done wrong please
All the other components are ok TRichview edit cause my Application was created with BCB6 and now I have C++Builder2007Codegear and it had not accepted all the print components.I have all erased the includes ans #pragma codes about them and try to recode.
I thank you very much.
I have again in an other directory the cpp file with component and code for BCB6 if I can recover without recode in Codegear says to me please
I thank you by advance
Patrick
OBJ files are placed in subdirectory. I do not exactly remember its name, but it seems it is either "Debug" or "Release", depending on the build mode.
Add this directory in the project options (or in the library paths for C++Builder)
Artaud
Richvieew .obj
Post by Artaud »
Thank you very much !!!!
