On the click of a button, I need to save two HTML files to disk from the same rvf document and in one go. The first file must have active HTML links and not the second file.
I know how to do that separately with SaveHTMLEx using or not using the OnWriteHyperLink event. However I don't know how to avoid triggering the OnWriteHyperLink when the second file (no active links) is written to disk. I don't really find my way through all the params and options of OnWriteHyperLink.
Thanks in advance for any help.
HTML with/without active hyperlinks?
Thanks, the de-assigning works. I reassign it like this :Sergey Tkachenko wrote:You may assign RichViewEdit1.OnWriteHyperlink := nil before saving the-no hyperlink file, and reassign it to the proper procedure when saving file with links.
RichViewEdit1.OnWriteHyperlink := RichViewEdit1.OnWriteHyperLink;
Is this the proper way to do it?
Hi Vega,
That last bit of code does not make much sense.
something like
would seem to be more useful
something like
oldEvent:=RichViewEdit1.OnWriteHyperlink;
RichViewEdit1.OnWriteHyperlink:=nil;
save stuff....
RichViewEdit1.OnWriteHyperlink :=oldEvent
Thanks dave novo. That did it.dave novo wrote:Hi Vega,
something like
would seem to be more usefulCode: Select all
oldEvent:=RichViewEdit1.OnWriteHyperlink; RichViewEdit1.OnWriteHyperlink:=nil; save stuff.... RichViewEdit1.OnWriteHyperlink :=oldEvent
