TCheckBox in RichView
BernhardRoos
Post by BernhardRoos »
I've post my problem here, too (in the private newsgroup I get no answer). But I'm working the whole day on this problem without success. And now I have no ideas anymore.
All what I want is to put Checkboxes with the Editor in a Richview Component which then should print or show in the Preview.
In the editor I only use InserControl.
The TCheckbox I have registered with RegisterControl(TCheckBox).
If I execute the report (the report has a Component tppRichView and the tppRichView has the Checkbox into) then the place is empty where the Checkbox should be print.
If I set the Checkbox with the editor in another color (for example black) then I see in the preview a black rectangle.
I'm using Delphi 2007.
What do I am wrong? Where can I find an example (without ScaleRichview, I must solve it with the normal TRichView Component).
Best wishes
Bernhard
Not all controls can be printed by default TRichView printing procedure.
If some controls are not printed, use OnPrintComponent event.
For checkboxes:
procedure TForm1.RVPrint1PrintComponent(Sender: TCustomRVPrint;
  PrintMe: TControl; var ComponentImage: TBitmap);
var r: TRect;
    State: Cardinal;
  if PrintMe is TCheckBox then begin
    ComponentImage := TBitmap.Create;
    ComponentImage.Width := PrintMe.Width;
    ComponentImage.Height := PrintMe.Height;
    ComponentImage.Canvas.Brush.Color := TCheckBox(PrintMe).Color;
    r := Rect(0,0, PrintMe.Width, PrintMe.Height);
    ComponentImage.Canvas.FillRect(r);
    if TCheckBox(PrintMe).Checked then
      State := DFCS_CHECKED
      State := 0;
    r.Right := r.Bottom;
    DrawFrameControl(ComponentImage.Canvas.Handle, r, DFC_BUTTON,
      DFCS_BUTTONCHECK or State);
    r := Rect(r.Right,0, PrintMe.Width, PrintMe.Height);
    ComponentImage.Canvas.Font := TCheckBox(PrintMe).Font;
    DrawText(ComponentImage.Canvas.Handle, PChar(' '+TCheckBox(PrintMe).Caption), -1, r,
      DT_VCENTER or DT_SINGLELINE);
BernhardRoos
Thanks for the answer. I've tried OnComponentPrint. But I'm not sure if I've assigned it correct because the debugger shows me it never receives this event. Where have I set this event (for which component or classes).
Have I set this event for each Item?
Can I have an example where I can assign this event?
Best wishes
Bernhard
BernhardRoos
In the Preview which is implemented in the ActionTest Demo I can RVPrint1 use to assign the Event OnComponentPrint.
But how can I do this if I use the Print/Preview of the Reportbuilder (using ppRichView.pas). There is a property Helper and Helper has a Property RichView and this has a property RVPrint, but RVPrint is nil. If I set RVPrint to a component TRVPrint and assign the OnComponentPrint, then nothing happens. The debugger shows me that this event never is executed.
How can I use the OnComponentPrint?
Best wishes
Bernhard
BernhardRoos
The debugger shows me further :
in RVItem.pas in TRVControlItemInfo.PrintingToBitmap in line 2266 the condition (RichView is TPrintableRV) is false. So the OnPrintComponent is not executed. What can I do that RichView is from type TPrintableRV?
And where can I assign the OnPrintComponent.
