There are many other problems if the Editor (from ActionTest) is used within the Wrapper for Reportbuilder.
Is there a Wrapper special for the ScaleRichView?
For the moment I can't get it run.
Best wishes
Bernhard
Wrapper for Reportbuilder and ScaleRichView
There are 2 possible using of ScaleRichView in ReportBuilder:
1) Replacing TRVReportHelper in ppRichView objects. I think it makes no sense. Drawing will be the same, but repagination is different. Currently, TRVReportHelper's repagination procedure is better then ScaleRichView's one (for example, ScaleRichView does not support page breaks in table cells yet)
2) Changing an editor form. Are there another problems, except for incorrect assignment of events?
I cant explain it exactly (my english is not so good), but at the moment I was not able to implement it that it works. Sometimes if I add a table the table is much more width than the page width. This happens, if I post my report (with the ppRichView component) and load it again and start again the Editor). Perhaps I do something wrong.
For the moment I'm using the normal TRichView (not the ScaleRichView) again. Perhaps I try it again in a few weeks with the ScaleRichView.
Best wishes
Bernhard
Best wishes
Bernhard
