GPF when printing
jimmaguire
GPF when printing
Post by jimmaguire »
I reproduced the error in MFEditor using the rvf I sent in a separate email. Its in the RVItem PrintToBitmap. The RVPrint is nil so the test of Assigned(...RVPrint.OnPrint...) fails.
I did modify the initialization of MFEditor to registerClasses TCheckBox and TPngObject
jimmaguire
It works in ActionsTest
I don't see the difference yet
jimmaguire
Sorry - was wrong - failed in ActionsTest as well
Same error
jimmaguire
Problem is due to printing TCheckbox
The TRVPrint has an OnPrintComponent that I use to print the check box. I don't see the same option on TSRVPrint
jimmaguire
Same error with TSRVCheckBox in MFInsertControls
I created a small rvf with just 1 check box and it fails on same line of code, thought TSRVCheckBox might work.
Did you send error report to Ilya?
jimmaguire
Yes
Sent sample
jimmaguire
Easy to reproduce with demos
Run InsertControls, open SRVControls.rvf and try its File/Print.
proxy3d
ScaleRichView Developer
Post by proxy3d »
1/ Bugs fixed in the update v1.3.4.
2/ > The TRVPrint has an OnPrintComponent that I use to print the check box. I don't see the same option on TSRVPrint
See OnPaintComponent in TSRichViewEdit
