Range Check error
jimmaguire
Range Check error
Post by jimmaguire »
I downloaded the new version this week, and tested with the ActionTest demo, looked great. But when I added that same unit to my application, I get a range check error in ScrRView on line 4634 hRGN := ... as soon as I do a Create of the form.
I created a form with just the TSRichViewEdit on it, no code, nothing else, and it gets the same error.
I don't expect this will be easy to find as it works fine as a stand alone form. Not sure what to do with it next. I know you will want a sample app, but its part of a large app that would be difficult to separate and reproduce.
TSRichViewEdit worked fine in the same app in prior releases. I got the same error with the form I had been using, so that's why I tried the ActionDemo. Let me know if you have any ideas.
jimmaguire
Using Delphi 2005
Forgot to mention that, also using Developers Express Menu and toolbar controls.
While, turn off Range Checking in the project's compiler options.
proxy3d
ScaleRichView Developer
Post by proxy3d »
Bugs fixed in the update v1.3.4.
