Archive of the old support newsgroups
Archive of the old newsgroups is available here:
http://www.trichview.com/support/newsgr ... rt_chm.zip (6.57M) - public newsgroups converted to HTML Help (CHM) format.
http://www.trichview.com/support/newsgr ... rt_dbx.zip (4.87M) - public newsgroups in Outlook Express (DBX) format.
If you still have not unsubscribed from the trichview newsgroups, copy these DBX files over the existing files. You can find the location of these files in Outlook Express: menu "Tools | Options", tab "Maintenance", button "Store Folder...".
Location of the archive of the private newsgroups is posted in the protected section of this forum.
Special thanks to: Bernard Nizet, Yernar Shambayev, David Novo.
Online version of the newsgroup archive:
trichview.support
http://www.trichview.com/support/trichv ... /index.htm
trichview.support.examples
trichview.support.thirdparty
