I have an question about TRichViewEdit
mariana
Post by mariana »
Can I draw circles, ellipses, lines or arrows in RichViewEdit?
I mean like in Word or Paint.
Can you help me please?
No, you can only insert pictures (TBitmap, TMetafile or other, inherited from TGraphic) or Delphi controls in text.
mariana
Post by mariana »
I have an project were in RichViewEdit I need to insert another RichViewEdit and write something in it. It's ok, it works, but when I save file the text writed in inserted control(RichViewEdit) don't save.What can I do to save text? Or can I save text from inserted controls?
And another question..
If I want to save file without text, only controls inserted how can I do that?
10x.
1) In order to load RVF file containing controls, you need to register them with RegisterClasses. For example, if you use TButton and TEdit in document, call:
RegisterClasses([TButton, TEdit]);
Do it one time before the first loading.
2) Sorry, I do not understand the second question. Do you want to remove all text from document?
mariana
Post by mariana »
Yes, I want to remove all text from document but my inserted controls to remain in initial position.
What you know, can I do that?
thankyou very much
This procedure deletes all text items from document:
uses CRVData, RVTable, RVNormalize;
procedure DeleteText(RVData: TCustomRVData);
var i,r,c: Integer;
  table: TRVTableItemInfo;
  for i := RVData.ItemCount-1 downto 0 do
    if (RVData.GetItemStyle(i)>=0) or (RVData.GetItemStyle(i)=rvsTab) then // text or tabulation
      RVData.DeleteItem(i)
    else if RVData.GetItemStyle(i)=rvsTable then begin
          if table.Cells[r,c]<>nil then
            DeleteText(table.Cells[r,c].GetRVData);
Call:
  RichViewEdit1.ClearUndo;
  DeleteText(RichViewEdit1.RVData);
  NormalizeRichView(RichViewEdit1.RVData);
  RichViewEdit1.Format;
RVNormalize is unit from RichViewActions (it can be used even if you do not use RichViewActions)
mariana
Post by mariana »
Thankyou very much for helping me..
It worked, but I have a little problem, I don't know how to save coordinates of inserted controls to remain where I introduced them, when deleting text the controls moves at the begin of line and I want to remain where I introduced them.
Have you an idea what can I do?
10x
In TRichView, controls are positioned in text, and if you remove text, controls will be moved.
Can you explain what do you want to implement, may be I will be able to suggest a solution.
mariana
Post by mariana »
I want to create a mask for create pages for printing, and save that page without text so that next time I want to create an page to insert the mask and write text into control.
I use inserted RichViewEdit to write text near an image introduced(to have near image more lines )
Like in next pothos:
Here is when I create the page..
Here is how i want to look after saveing.
Have you understand what I want to do?
Sorry, I am afraid it's not possible. It requires positioning items at the specified coordinates (unsupported by TRichView)
mariana
Post by mariana »
Ok.
Thankyou very much, again.
mariana
Post by mariana »
I tried to introduce an PaintBox in RichViewEdit, but at preview time I couldn't see it and neither what is drawn in it.
Know you what can I do to view them, or it is impossible to do that?
If some components are not printed, you can help TRichView to print them.
Process TRVPrint.OnPrintComponent event. In this event, if the component is TPaintBox, create a bitmap (having the same size as the paint box) and draw the paint box on it.
If you need further help, let me know.
mariana
Post by mariana »
Hi.. thanks for your help
I have another question..
I introduced an RichViewEdit into another RichViewEdit and save the file with extension rvf, but when I load into aplication the text writed inti the inserted RichViewEdit isn't loaded.. I think that wasn't saved.
What can I do to save text in inserted RichViewEdit?
I registered class in constructor whit function RegisterClasses..
Thank you..
It's not so simple to insert RichViewEdit in RichViewEdit, because:
- it has link to TRVStyle, and links are not saved in RVF;
- it does not save its document together with its properties.
This demo shows how to solve these problems: http://www.trichview.com/forums/viewtopic.php?t=2199
