rvhtmlimport - List Index Out Of Bounds (1)
bgl
Post by bgl »
When importing the below specified HTML using RVHTMLImport into a TRichViewEdit, and then performing a left mouse click - An Exception occurs : List Index Out Of Bounds (1).
<font size=2 color="#000000" face="Arial">
<ol>
<li value=1></li>
</ol>
</font>
Other HTML code seems to import fine. I am using version 1.9.24, and latest RVHTMLImport component. The problem came up during testing, and is likely to occur again during normal operation of our application.
The problem can be reproduced using the demo application that ships with RVHTMLImport. Can anyone else confirm the problem?
Thanks,
Elliot
In some cases, RvHtmlImporter generates invalid documents (see "Valid Documents" topic in the help file).
It can be fixed by calling NormalizeRichView(RichView1.RVData) after RvHtmlImporter1.LoadHtml.
NormalizeRichView is from RVNormalize unit, included in RichViewActions (but can be used separately)
