TRichViewEdit and server DLL
prosoft
Post by prosoft »
I want to create file on remote database server and this file send by email.
My problem is that TRichView wants parent window.
I have to use TRichView encapsulated in dll library.
Sergej wrote in december 2005 that this limitation will removed in next release.
http://www.trichview.com/forums/viewtop ... ght=parent
Is any new in this issue?
Is any chance how can i create document without view (parent window)
Josef.
In the latest version (available for registered users) TRVReportHelper does not require parent.
prosoft
Post by prosoft »
Yes, it works without parent.
But i have next problem. Can i use TRVReportHelper for creating documents?
My problem is that i want to create documents on server side by DLL library with TRVReportHelper and save it by RichView.SaveRTF method.. When i insert text i have no problem. But when i add table by AddItems procedure to document, RichView.SaveRTF raise exception 'AccessViolation' in
TCustomRVFormattedData.Format
What can be wrong? Is this using of TRVReportHelper right?
Saving RTF with tables requires formatted document (because table grid must be calculated).
If SaveRTF detects that table is not formatted, it tries to format it. But if TRVReportHelper is not initialized, it fails.
Solution: call RVReportHelper.Init with any width as a parameter before calling SaveRTF.
