Load From Stream Not Saving to Dataset
btucker21
Post by btucker21 »
I am copying the contents from a TRichViewEdit to a TDBRichViewEdit using the following code. The contents copies perfectly. However, when I post the record linked to the TDBRichViewEdit, the contents reverts back to what it was before the edit. It seems to me that the record buffer is not getting notified that it has changed. If I manually make a slight change to the contents after it I saved in the TDBRichViewEdit, then the record posts correctly. Any thoughts?
vContents :=TMemoryStream.Create;
RichViewEdit1.SaveRVFToStream(vContents, False);
if vContents.Size<1 then
TempMemo.Clear
TempMemo.Clear;
TempMemo.DeleteUnusedStyles(True, True, True);
TempMemo.Format;
vContents.Position :=0;
TempMemo.LoadRVFFromStream(vContents);
TempMemo.Format;
TempMemo.ScrollTo(0);
End;
Thanks,
Change LoadRVFFromStream to InsertRVFFromStreamEd.
Additional information can be found in the help file, example 1 ("Using viewer-style methods in DBRichViewEdit") in the topic about TDBRichViewEdit.
btucker21
Post by btucker21 »
Worked correctly.
Thanks for the prompt and helpful response.
