How I can a marked table-cell the cell-color alter
Jmich
Post by Jmich »
Do you want to know how to change background color for selected cells?
This code makes the selected cells red (as an editing operation):
procedure TForm1.Color1Click(Sender: TObject);
var rve: TCustomRichViewEdit;
  table: TRVTableItemInfo;
  r,c,i: Integer;
  if not RichViewEdit1.CanChange or
     not RichViewEdit1.GetCurrentItemEx(TRVTableItemInfo, rve,
       TCustomRVItemInfo(table)) then
  rve.BeginUndoGroup(rvutModifyItem);
  rve.SetUndoGroupMode(True);
        if (table.Cells[r,c]<>nil) and (table.IsCellSelected(r,c)) then
          table.SetCellColor(clRed, r,c);
    rve.SetUndoGroupMode(False);
  rve.Change;
Or do you want to use another color to highlight selection?
In this case, see properties of TRVStyle: SelColor, SelTextColor, InactiveSelColor, InactiveSelTextColor.
