[Demo] DB Editor
[Demo] DB Editor
http://www.trichview.com/support/files/dbeditdemo.zip
This is an analog of the demo Demos\Delphi\Editors\Editor 2\, but with TDBRichViewEdit instead of TRichViewEdit.
This demo implements basic commands for changing text and paragraph attributes (without RichViewActions)
This ZIP file includes several versions of this demo:
  • BDE (Paradox table)
  • FireDAC (InterBase table)
  • ADO / dbGo (Microsoft Access 2010 table)
[+] Updates
2019-Jul-08: ADO with MS Access demo is added.
2018-Apr-16: in addition to BDE demo, I added FireDAC demo with InterBase table. The demo was created in Delphi 10.2, the table was created using InterBase 2017, but I hope they work in older versions of Delphi and InterBase too.
Nostradamus
Project does not compile in Delphi 2010
Post by Nostradamus »
I could not get this DB project to compile on Delphi 2010.
Any help is appreciated
I have windows 7 - 64 bit
thanks and
Happy New Year
Richard[/img]
This demo uses BDE and Paradox table.
Probably, you did not install BDE support when installing Delphi.
Also, Win7 may have problems working with BDE (this demo works fine on Win8, though)
You can try using another DB engine - replace Table1: TTable to you favorite DB dataset components.
A table must have Document field able to store arbitrary binary data.
Nostradamus
project is working now...
I tried the project again today and it works now.
Serge
PS I am still using Windows 7
Re: [Demo] DB Editor
FireDAC version of this demo is added (in the same ZIP file)
Nostradamus
HI SERGEY,
I TRIED THE FIREDAC VERSION IT DOES NOT WORK WITH DELPHI 2010.
I USUALLY TEND TO USE ADO COMPONENTS WITH MS ACCESS AS THIS IS THE ONLY DATABASE .mdb THAT WORKS WITH OLE JET 4 DB PROVIDER
WHEN
BUILDING DATABASE CONNECTION.
I'll try to make an example in the next couple of days.
The main problem with MS Access, as far as I understand, the lack of field type for storing arbitrary binary data (required for RVF).
Unfortunately, even "text mode" RVF is not really a plain text and requires a binary field.
Well, there is a solution: use a memo field and encode RVF in a text string (using a hexadecimal code or base64). I'll implement it in the demo.
I added ADO+Access version of this demo.
As I said above, the main difficulty was storing binary RVF data in a text (memo) field.
I used the simplest possible binary-to-text encoding - hexadecimal code. It is simple and fast, but increases data size by 100%.
A better alternative would be Base64 encoding, it increases data size only by 33%.
Unfortunately, base64 functions were included in Delphi only since XE7, and you need Delphi 2010 version. You can use DIMime for base64 encoding.
Nostradamus
I am trying to get back into things while I still have some free time...
in this project you mention a datafile... 'DemoData.ib'
Can I have a copy of this file ?
Richard
// Filling font names combobox
cmbFont.Items.Assign(Screen.Fonts);
// Opening table
with FDConnection1.Params do
Clear;
Add('DriverID=IB');
Add('Database=localhost:' + ExtractFilePath(Application.ExeName) + 'DemoData.ib');
Add('User_Name=SYSDBA');
Add('Password=masterkey');
FDConnection1.Connected := True;
FDTable1.Open('');
DemoData.ib is included
Nostradamus
OK My error... I forgot to install RAD SERVER
still get error message though...
DBEditl: Field Title' not found.
see attached error message also.
cheers
Richard
DB_Editor demo_error_message.png (55.92 KiB) Viewed 308978 times
Nostradamus
I finally got the FireDC_IB project working today
Merry Xmas
