Need help to remove tables from RV
kdu
Post by kdu »
Hi community,
I am work with BDS 2006.
I need a function to change tables to text nearly as found here:
http://www.trichview.com/forums/viewtopic.php?t=581
The example removes the tables and put the text from each table in one new line. The problem: I want to have all tabletext found in a Item together in a new item using tabs as separator.
My concept was to modify the RTF-Stream but when I am using "SaveRTFToStream" in place of "SaveRVFToStream"
......snip......
		if(table->Rows->Items[r]->Count)
			TMemoryStream*Stream = new TMemoryStream;
			for (int c=0; c<table->Rows->Items[r]->Count; c++)
				if(table->Cells[r][c])
				   //	table->Cells[r][c]->GetRVData()->SaveRVFToStream(Stream, false,clNone, NULL, NULL);
				   	[color=red]table->Cells[r][c]->GetRVData()->SaveRTFToStream(Stream, false,clNone, NULL, NULL);[/color]
			Stream->Position = 0;
			Stream->SaveToFile("Test.rtf");
			rv->InsertRVFFromStream(Stream, rv->ItemCount);
         delete Stream;
......snip......
I got this errors:
E2015 Mehrdeutigkeit zwischen '_fastcall System::AnsiString::AnsiString(char)' und '_fastcall System::AnsiString::AnsiString(short)'
E2342 Keine Übereinstimmung des Typs beim Parameter 'Path' ('const AnsiString' erwartet, 'bool' erhalten)
W8006 TColor wird mit int initialisiert
:evil:
Any solution or bit code to solve the problem?
Regards and thanx for help
KDU
Oh, RVData->SaveRTFToStream has a bunch of parameters.
Call
table->Cells[r][c]->GetRVData()->SaveRTFToStream(Stream, '', false, 0,  clNone, NULL, NULL, NULL, NULL, NULL, 0, true);
(the last parameter was added in a recent version)
