Hi
I'm having a look at your component. I like it very much. We will probably register it soon.
I just have a big problem and I don't know how to solve it:
We have a MS SQL Database and we need to put RTF Text of the DBRichViewEdit in a DB-Field (Fieldtype TEXT). We need to store it like this to show it in Crystal Report.
I set FieldFormat to rvdbRTF and ParaStyleMode and TextStyleMode to rvrsAddIfNeeded. If I just want to display the RTF-Text stored in the DB, everything works fine. But if I want to update or insert data, the hole RTF-Text shows in the DBRichViewEdit and not just the text the user typed in.
Any suggestions how I can solve this problem?
Thanks in advance.
Problem Saving with TDBRichViewEdit
