Trying to use addict3 (a3pro35) in combination with richview (latest rvpkg)
using ad3simpledemo - compiles and works fine
take that and make it based around an activeform in delphi7
and it doesn't work, error highlighting fails to show unless
click spell check button then new text is not correctly flagged
live spell check settings and so forth exactly as is
highlighting disappears arbitrarily and no
toggle of startlivespelling and clearlivespellingresults
will address issues
is it possible to use richview in an activeform?
is it possible to take your addict-richview demo and make it work
on an activeform?
richview ad3simpledemo
in fact i have greater problems with the richview controls
i cannot get livespelling in addict3 and richview to work together using simple basic components - a simple demo generates exceptions
anyone using addict with richview? can you successfully use the latest richview update and the latest addict update together?
thank-you
thank-you
