I just got an email from my client telling me that she tried printing out two documents that looked good in the TScaleRichView but they didn't print correctly - one was larger and one was smooshed.
I can't try anything until I get back to the ofice with a printer.
I want to make sure I have the settings correctly as there are a lot of them which I am sure affect the printing.
Best Regards,
Shane
Printing Settings?
What I sometimes use for testing is PDFCreator http://sourceforge.net/projects/pdfcreator/. Maybe an option when you're unable to get to a printer (or just to save some paper).
Pieter
Pieter
Peter,
Thanks for the suggestion. The users are reporting that the documents are printing out different than what they look like in the editor.
I will add a PDF export tonight also for testing.
I will have to test and report back later tonight. I just want to make sure I have any "special" properties set so I don't spend a lot of time on just trying to get a document to print.
Best Regards,
Shane
Best Regards,
Shane
