Auto calculate reporter height
pdcuser
Post by pdcuser »
I am using the TRVReportHelper component to paint RVF text to a Canvas. Given a canvas of x width, I want to determine the height the canvas has to be in order to see the wordwrapped text. The problem I am having is the last word on the line seems to disappear occasionally, instead of wordwrapping.
Assuming there is only one paragraph (no carriage returns), and only one text style being used, I have tried:
function TMyControl.GetPlainText: WideString;
  Convert RVF to widestring...
function TMyControl.GetFontHeight: Integer;
  Get the current font height...
procedure TMyControl.BeforeDraw;
  PlainText: string;
  TextWidth, TextHeight: Integer;
  Canvas.Font.Assign(Font);
  PlainText := RVU_GetRawUnicode(GetPlainText);
  TextHeight := GetFontHeight;
  TextWidth := RVU_TextWidth(PlainText, Canvas, [rvioUnicode]);
  // Set the canvas height
  Height := TextHeight * Ceil(TextWidth / Width);
How can I determine the correct height to ensure all text is displayed on the canvas?
Thanks in advance,
Brandon
For the last page, you can use RVReportHelper.GetLastPageHeight.
pdcuser
Post by pdcuser »
That did it. Thanks again!
