OnCurTextStyleChange??
Shane Stump
Post by Shane Stump »
Why does this event get called sometimes 3 to 4 times when the user clicks in a different part of the document (especially tables)? I would figure it would only get called ONCE.
Best Regards,
Shane
This behavior is inherited from TRichViewEdit. Yes, in some cases, OnCurTextStyleChange can be called several times.
I do not think that this is a serious problem.
Shane Stump
Well, it killed a feature I was trying to add because of the # of times it was called. I was just going to check if the FontName / Size was the same and eat "repetitive" calls but many times clicking in a different section of the document gets multiple font/size combinations when really there shoud only be one.
Shane
Several calls of this event make no problem in all demos and real applications that use TRichViewEdit/ScaleRichView. And none of them implement special processing for this.
This event is never called with incorrect parameters, so they are called several times with the same value of CurTextStyleNo.
Shane Stump
Well, it was causing me all kinds of problems trying to load a devexpress lookup control. As I said, I would simply filter the repetitive calls but several times an Arial, Font 10 got stuck in between when it shouldn't.
Any how, I just gave up because I have already spent more time on this than I have for it. I just want to get a basic WYSIWUG document editor going and I will put it to bed for now.
I have everything working except my users are telling me printing isn't correct. I cut / paste / translated the pascal code (which wasn't much) to c++. I will have to wait and test later this evening.
Best Regards,
Shane
"Arial 10" glitch is confirmed, will be fixed in the next update of TRichView
