TRVTextItemInfo
MichaelS
TRVTextItemInfo
Post by MichaelS »
I'm iterating a table with his cells. In a cell I have different TCustomRVItemInfo classes. Now I have to extract from every cellitem, which is a TRVTextItemInfo, the RVData into a Stream.
Do you have a fast solution for me? Thanks in Advance!
Yours,
Michael
Sorry, I do not understand. Can you explain in another words?
MichaelS
Post by MichaelS »
Sorry, my englisch isn't so good. Here my problem in another words:
I have a TRichViewEdit component, which contains a table with formatted text. Now I would like to extract, for each tablecell the formatted text into a RV-Stream.
Here a example:
  intIndex: Integer;
  objData: TRVEditRVData;
  objItem: TRVTableItemInfo;
  objCell: TRVTableCellData;
  intRow: Integer;
  intCol: Integer;
  intCount: Integer;
  objData := TRVEditRVData(rvEdit.RVData);
  for intIndex := 0 to rvEdit.ItemCount-1 do
    if objData.GetItem(intIndex) is TRVTableItemInfo then
      objItem := TRVTableItemInfo(objData.GetItem(intIndex));
      for intRow := 0 to objItem.RowCount -1 do
        for intCol := 0 to objItem.ColCount - 1 do
          objCell := objItem.Cells[intRow, intCol];
          for intCount := 0 to objCell.ItemCount - 1 do
            if objCell.GetItem(intCount) IS TRVTextItemInfo then
              // => here save for each TRVTextItemInfo the RV-Text
Thanks in Advance.
Yours,
Michael
  intIndex: Integer;
  intRow: Integer;
  intCol: Integer;
  intCount: Integer;
[color=blue]          if objCell=nil then
            continue;[/color]
          for intCount := 0 to objCell.[color=blue]GetRVData.[/color]ItemCount - 1 do
            if objCell.[color=blue]GetRVData.[/color]GetItem(intCount) IS TRVTextItemInfo then
              [color=blue]{ Use objCell.GetRVData.GetItemTextA(intCount) }[/color]
In addition, you can:
- for TRVTabItemInfo items, add #9 in text
- if objCell.GetRVData.IsFromNewLine(intCount), add #13#10
MichaelS
Post by MichaelS »
Hello Sergey,
it works fine! Thanks a lot!
Yours,
Michael
