First, detecting url while typing is ok.
I already tested your demos.
But I have another question about this.
In your \Assorted\Hypertext\URLs demo,
what I want is append the content to another richview,
then click url on richview, but I fail
Here is my code
myStream : TMemoryStream;
myStream := TMemoryStream.Create();
if RichViewEdit1.SaveRVFToStream(myStream, false) then
myStream.Position := 0;
RichView1.AppendRVFFromStream(myStream, 0);
RichView1.Format;
myStream.free;
the error will occur in "RichView1.AppendRVFFromStream(myStream, 0);"
It will popup an error says
EConvertError, "www.richedit.com" is not a valid integer value.
Please advise
Question about the detecting url while typing
Here is my another test.
I wrote new demo to test the code to detecting url.
In my test,
I add two event to my richviewedit (copy from your URLs demo),
procedure TForm1.rveKeyDown(Sender: TObject; var Key: Word;
Shift: TShiftState);
if Key in [VK_SPACE, VK_RETURN] then begin
// url detection
DetectURL(rve, URLScanEvent, True);
// closing url if necessary
TerminateHyperlink(rve, URLScanEvent);
procedure TForm1.rveJump(Sender: TObject; id: Integer);
var RVData: TCustomRVFormattedData;
ItemNo: Integer;
url: String;
rve.GetJumpPointLocation(id, RVData, ItemNo);
url := PChar(RVData.GetItemTag(ItemNo));
ShellExecute(0, 'open', PChar(url), nil, nil, SW_SHOW);
then I input a url to edit, then use the same function to append to richview
procedure TForm1.Button3Click(Sender: TObject);
r: Boolean;
if rve.SaveRVFToStream(myStream, false) then
RichView1.Format;
SendMessage(RichView1.Handle,WM_VSCROLL,SB_BOTTOM,0);
myStream.free;
It works fine to append url to richview, BUT..
1) use CTRL + mouse click to click url in richviewedit, it will popup the directory of my program, not browser to the url.
2) mouse click on url on richview, it will cause access violation error.
Please advise
In my test,
// url detection
ItemNo: Integer;
url: String;
r: Boolean;
RichView1.Format;
myStream.free;
Please advise
