Vista Theme compatibility.
KWBOB
Post by KWBOB »
Do you have any plans to add compatibility to Richview running on Vista with the Vista basic Theme?
I thought that enabling XP themes enables using Vista theme too...
KWBOB
Post by KWBOB »
We have a web page building application using trichview. When we run on vista and load up our web page with tables in, the formatting is incorrect. If I use the trichview.format command after changing the table border width the formatting is all over the place. I have emailed you some screen shots demonstrating the problem.
If we change the display theme to Windows Classic the problem disappears.
Can you send me a simple project to reproduce this bug?
KWBOB
Post by KWBOB »
Many Apologies. I am Unable to reproduce this outside of our application.
lummie
Did you solve this ?
Post by lummie »
I have the same, various tables with embeded controls in the cells, the richview paints the controls at random places, resizing the window sometimes causes it to position the controls in the cells correctly, sometimes not.
This only happens under vista with Window Vist Basic appearance, if I set vista to windows Stanard Appearance it all works.
Did you find a solution
Finally, the problem is confirmed and wil be fixed in the next update.
