Hi, Sergey,
Your help is needed again. In my application I have, on printing, to replace controls' images as they look with text they contain. The problem is that when using RVPrint component's internal RV property the actual contents of RichViewEdit is affected, i.e. controls are replaced with text. How to do that contents of RichviewEdit remain unaffected?
This is a code example:
procedure TfrmMain.ToolButton4Click(Sender: TObject);
var i, ATag: integer;
AName, S: string;
ACtrl: TControl;
AVAlign: TRVVAlign;
RVPrint1.AssignSource(RVEdit);
for i:= 0 to RVPrint1.rv.ItemCount - 1 do
if RVPrint1.rv.GetItem(i).StyleNo <> rvsComponent then Continue;
RVPrint1.rv.GetControlInfo(i, AName, ACtrl, AVAlign, ATag);
RVPrint1.rv.GetItem(i).StyleNo:= 0;
if ACtrl is TDBEditEh then RVPrint1.rv.SetItemTextA(i, TDBEditEh(ACtrl).Text)
RVPrint1.rv.SetItemTextA(i, 'Text Example!');
RVPrint1.FormatPages(rvdoAll);
rvActionPrintPreview1.Execute;
Best regards, Eugene Kruglov
Contents of RichViewEdit changes when printing
Sergey,
Sorry, I am probably stupid, but your advice did not help. I create TRichViewEdit, fill it with contents of another TRichViewEdit, then try to 'process' it (i.e. replace controls with text). When I change the text in the control the preview seems not to change at all!
Code fragment (sorry for large size!):
function TfrmMain.CreateTemporaryPrintRichViewEdit(Source: TRichViewEdit): TRichViewEdit;
procedure ReplaceItemText(RichView: TRichViewEdit; ItemNo: integer; NewText: string);
var S: string;
S:= NewText;
ReplaceSymbols(S, #13, '');
ReplaceSymbols(S, #10, '');
RichView.GetItem(ItemNo).StyleNo:= 0;
RichView.SetItemTextA(ItemNo, S)
AName: string;
ACtrl: TControl;
AVAlign: TRVVAlign;
MemStream: TMemoryStream;
//NewStyle: TRVStyle;
{with RVPrint do
LeftMarginMM:= 0;
RightMarginMM:= 0;
PreviewCorrection:= true;
end;}
if FindComponent('PrintRVEdit') <> nil then PrintRVEdit:= TRichViewEdit(FindComponent('PrintRVEdit')) else
PrintRVEdit:= TRichViewEdit.Create(Self);
PrintRVEdit.Name:= 'PrintRVEdit';
with PrintRVEdit do
Visible:= false;
Style:= TRVStyle.Create(Self);
Color:= clWindow;
RVFOptions:= [rvfoSavePicturesBody, rvfoIgnoreUnknownCtrls, rvfoSaveBinary, rvfoSaveBack,
rvfoLoadBack, rvfoSaveTextStyles, rvfoSaveParaStyles, rvfoSaveLayout, rvfoLoadLayout,
rvfoSaveDocProperties, rvfoLoadDocProperties];
Options:= [rvoAllowSelection, rvoScrollToEnd, rvoShowPageBreaks, rvoTagsArePChars, rvoAutoCopyText,
rvoAutoCopyRVF, rvoAutoCopyImage, rvoAutoCopyRTF, rvoFormatInvalidate, rvoDblClickSelectsWord,
rvoRClickDeselects,rvoFastFormatting];
OnRVFControlNeeded:= RVEditRVFControlNeeded;
Parent:= Self;
with PrintRVEdit do
MemStream:= TMemoryStream.Create;
Source.SaveRVFToStream(MemStream, false);
MemStream.Position:= 0;
Clear;
LoadRVFFromStream(MemStream);
Format;
for i:= 0 to ItemCount - 1 do
if GetItem(i).StyleNo <> rvsComponent then Continue;
if not (ACtrl is TDBGridEh) then ReplaceItemText(PrintRVEdit, i, '(???)'); //первоначальное значение
if ACtrl is TDBEditEh then ReplaceItemText(PrintRVEdit, i, (ACtrl as TDBEditEh).Text);
if ACtrl is TDBLookupComboboxEh then ReplaceItemText(PrintRVEdit, i, TDBLookupComboboxEh(ACtrl).Text);
if ACtrl is TDBNumberEditEh then ReplaceItemText(PrintRVEdit, i, TDBNumberEditEh(ACtrl).Text);
if ACtrl is TDBDateEdit then ReplaceItemText(PrintRVEdit, i, TDBDateEdit(ACtrl).Text);
if ACtrl is TRxCalcEdit then ReplaceItemText(PrintRVEdit, i, TRxCalcEdit(ACtrl).Text);
if ACtrl is TDBCheckBoxEh then ReplaceItemText(PrintRVEdit, i, YesNo[Integer(TDBCheckBoxEh(ACtrl).Checked)]);
if ACtrl is TLabel then ReplaceItemText(PrintRVEdit, i, TLabel(ACtrl).Caption);
if ACtrl is TEdit then ReplaceItemText(PrintRVEdit, i, TEdit(ACtrl).Text);
if ACtrl is TMemo then ReplaceItemText(PrintRVEdit, i, TMemo(ACtrl).Text);
//if ACtrl is TCheckBox then ReplaceItemText(PrintRVEdit, i, TCheckBox(ACtrl).Text);
if ACtrl is TRadioButton then ReplaceItemText(PrintRVEdit, i, YesNo[Integer(TRadioButton(ACtrl).Checked)]);
if ACtrl is TComboBox then ReplaceItemText(PrintRVEdit, i, TComboBox(ACtrl).Text);
//if ACtrl is TButton then ReplaceItemText(PrintRVEdit, i, TButton(ACtrl).Text);
//if ACtrl is TBitButton then ReplaceItemText(PrintRVEdit, i, TBitButton(ACtrl).Text);
//if ACtrl is TSpeedButton then ReplaceItemText(PrintRVEdit, i, TSpeedButton(ACtrl).Text);
if ACtrl is TMaskEdit then ReplaceItemText(PrintRVEdit, i, TMaskEdit(ACtrl).Text);
//if ACtrl is TShape then ReplaceItemText(PrintRVEdit, i, TShape(ACtrl).Text);
if ACtrl is TRadioGroup then ReplaceItemText(PrintRVEdit, i, TRadioGroup(ACtrl).Caption + ': ' + TRadioGroup(ACtrl).Items.Strings[TRadioGroup(ACtrl).ItemIndex]);
if ACtrl is TDBDateTimeEditEh then ReplaceItemText(PrintRVEdit, i, TDBDateTimeEditEh(ACtrl).Text);
if ACtrl is TDBComboBoxEh then ReplaceItemText(PrintRVEdit, i, TDBComboBoxEh(ACtrl).Text);
Format;
MemStream.Free;
Result:= PrintRVEdit;
Another accompanying question: why sometimes after creating TRichViewEdit at runtime it reacts only to BackSpace key (i.e. text is deleted) but does not do to Delete key? I can't understand what it depends on...
Awaiting reply, Eugene
var S: string;
S:= NewText;
AName: string;
ACtrl: TControl;
AVAlign: TRVVAlign;
{with RVPrint do
LeftMarginMM:= 0;
RightMarginMM:= 0;
end;}
with PrintRVEdit do
Visible:= false;
Color:= clWindow;
Parent:= Self;
with PrintRVEdit do
Clear;
Format;
Format;
MemStream.Free;
Hi, Sergey!
Sorry for my stupidity, I have done it! I've forgotten that when I perform the SaveToStream/LoadFromStream actions all my controls are copied only as their text representations and restored in OnRVFControlNeeded event handler. Hence, they (after copyiing) can not reflect the changes made to original controls.
The another problem was really foolish: Delete did not work because it was implemented as shortcut in main menu
Best regards, Eugene.
Thank you for your work.
